检测表面粗糙度的光纤传感器研究
消耗积分:10 | 格式:rar | 大小:258 | 2009-07-10
梅利号
分享资料个
论述了测量表面粗糙度的反射散射比光纤传感器的结构、工作原理。介绍了它具有的抗干扰能力强、测量精度高、重复性好、可测微小面积和孔洞底面等异型表面等特点。给出了实测结果,并对影响测量的各种因素进行了分析讨论。
关键词: 表面粗糙度; 光纤传感器; 反射散射比; 半导体激光器
Abstract : A newfiber sensor for measuring surface roughness using ratio of diffuse and reflections is introduced. It expatiates the structure , working principle and characteristic of the fiber sensor , and the practically measuring result is given. The fiber sensor has strong ability of anti2jamming , high survey precision , good replication quality , and can measure exiguity surface and bottom surface of the hole. The factor which affecting the measurement are analyzed and discussed.
Key words : Surface roughness ; Fiber sensor ; Ratio of reflect and diffuse ; Semiconductor laser
评论(0)
发评论
下载排行榜
