ad7541 pdf
消耗积分:5 | 格式:rar | 大小:444 | 2008-06-06
王磊
分享资料个
The AD7541 is a monolithic, low cost, high performance,
12-bit accurate, multiplying digital-to-analog converter
(DAC).
Intersil’ wafer level laser-trimmed thin-film resistors on
CMOS circuitry provide true 12-bit linearity with TTL/CMOS
compatible operation.
Special tabbed-resistor geometries (improving time stability),
full input protection from damage due to static discharge by
diode clamps to V+ and ground, large IOUT1 and IOUT2 bus
lines (improving superposition errors) are some of the features
offered by Intersil AD7541.
Pin compatible with AD7521, this DAC provides accurate
four quadrant multiplication over the full military temperature
range.
评论(0)
发评论
下载排行榜
