4013 CMOS 带置位-复位的双D触发器
消耗积分:10 | 格式:rar | 大小:74 | 2009-08-08
张磊
分享资料个
The CD4013B dual D-type flip-flop is a monolithic complementary
MOS (CMOS) integrated circuit constructed with
N- and P-channel enhancement mode transistors. Each
flip-flop has independent data, set, reset, and clock inputs
and “Q” and “Q” outputs. These devices can be used for
shift register applications, and by connecting “Q” output to
the data input, for counter and toggle applications. The
logic level present at the “D” input is transferred to the Q
output during the positive-going transition of the clock
pulse. Setting or resetting is independent of the clock and
is accomplished by a high level on the set or reset line
respectively.
评论(1)
发评论
很好 2011-09-08
0 回复 举报
不错 收起回复
下载排行榜
全部1条评论
