74151 TTL 8选1数据选择器
消耗积分:10 | 格式:rar | 大小:254 | 2009-08-08
分享资料个
These data selectors/multiplexers contain full on-chip decoding
to select the desired data source. The 150 selects
one-of-sixteen data sources; the 151A selects one-of-eight
data sources. The 150 and 151A have a strobe input which
must be at a low logic level to enable these devices. A high
level at the strobe forces the W output high and the Y output
(as applicable) low.
The 151A features complementary W and Y outputs,
whereas the 150 has an inverted (W) output only.
The 151A incorporates address buffers which have symmetrical
propagation delay times through the complementary
paths. This reduces the possibility of transients occurring at
the output(s) due to changes made at the select inputs, even
when the 151A outputs are enabled (i.e., strobe low).
评论(0)
发评论
下载排行榜
