爱普生FA-238V智能健身镜专用晶振Q22FA23V0048200
消耗积分:0 | 格式:docx | 大小:775.57 KB | 2024-07-23
Piezoman压电侠
  • 914内容
  • 91w+阅读
  • 69粉丝
     智能健身镜,是一款人工智能+互联网技术深度结合的智能健身产品,它打破了传统健身所固有的模式,让足不出户的我们也能拥有健康的生活,那么智能健身镜使用到哪些晶振?
    晶振在智能健身镜的作用:智能健身镜是以硬件+内容为载体,支持蓝牙或Wi-Fi连接,通过虚拟教练来为用户健身,提供实时 指导与反馈,同时自带的AI摄像头和识别传感器,能够对用户的动作进行实时纠正。
    对于智能健身镜这样智能化的电子产品来说,人机交互、语音识别等功能的实现必然离不开晶振的支持。这些晶振的作用主要 负责实时时钟、程序指令时钟、蓝牙数据传输、开机、网关、有线网络数据、无线网络数据(WIFI)等。
    日本爱普生晶振FA-238V编码Q22FA23V0048200是一款小体积尺寸3.2x2.5m四脚贴片晶振,无源晶振,石英晶体谐振器,FA-238V频率范围 12MHz至15.9999MHz之间,可以在-40℃至+85℃(+105℃)温度内稳定工作,该产品具有小体积轻薄型,耐热、耐振、耐冲击等 优良的耐环境特性,适用于智能健身镜,移动通讯,智能手机,平板电脑,汽车电子,移动电话,无线蓝牙,ISM频段电台广 播,MPU时钟等.
产品编码贴片晶振型号频率负载电
精度频率公差工作温度
Q22FA23V00441003.2x2.5x0.7mmFA-238V12.288000MHz2pF+/-20ppm+/-30ppm-20to+70℃
Q22FA23V00448003.2x2.5x0.7mmFA-238V13.333000MHz7pF+/-50ppm+/-30ppm-20to+70℃
Q22FA23V00451003.2x2.5x0.7mmFA-238V12.288000MHz0pF+/-50ppm+/-50ppm-40to+85℃
Q22FA23V00452003.2x2.5x0.7mmFA-238V12.000000MHz7pF+/-50ppm+/-30ppm-20to+70℃
Q22FA23V00459003.2x2.5x0.7mmFA-238V2.000000MHz2pF+/-20ppm+/-30ppm-20to+95℃
Q22FA23V00465003.2x2.5x0.7mmFA-238V14.318000MHz33pF+/-50ppm+/-50ppm-20to+70℃
Q22FA23V00467003.2x2.5x0.7mmFA-238V12.500000MHz6pF+/-30ppm+/-30ppm-20to+70℃
Q22FA23V00477003.2x2.5x0.7mmFA-238V12.000000MHz2pF+/-100ppm+/-30ppm-20to+70℃
Q22FA23V00481003.2x2.5x0.7mmFA-238V14.920000MHz0pF+/-50ppm+/-30ppm-20to+70℃
Q22FA23V00482003.2x2.5x0.7mmFA-238V12.000000MHz2.5pF+/-30ppm+/-30ppm-40to+85℃
Q22FA23V00484003.2x2.5x0.7mmFA-238V2.000000MHz8pF+/-20ppm+/-20ppm-30to+85℃
Q22FA23V00485003.2x2.5x0.7mmFA-238V12.000000MHz12pF+/-10ppm+/-20ppm-10to+95℃
Q22FA23V00486003.2x2.5x0.7mmFA-238V14.745600MHz0pF+/-30ppm+/-30ppm-20to+70℃
Q22FA23V00498003.2x2.5x0.7mmFA-238V13.333000MHz2pF+/-50ppm+/-30ppm-20to+70℃
Q22FA23V00504003.2x2.5x0.7mmFA-238V12.288000MHz8pF+/-20ppm+/-30ppm-20to+70℃
Q22FA23V00505003.2x2.5x0.7mmFA-238V12.288000MHz8pF+/-20ppm+/-20ppm-20to+70℃
Q22FA23V00513003.2x2.5x0.7mmFA-238V15.980000MHz8pF+/-15ppm+/-15ppm-20to+70℃
Q22FA23V00519003.2x2.5x0.7mmFA-238V12.000000MHz22pF+/-20ppm+/-20ppm-30to+85℃
Q22FA23V00521003.2x2.5x0.7mmFA-238V12.000000MHz20pF+/-20ppm+/-30ppm-20to+70℃
Q22FA23V00527003.2x2.5x0.7mmFA-238V12.288000MHz9pF+/-20ppm+/-20ppm-20to+70℃
Q22FA23V00529003.2x2.5x0.7mmFA-238V12.000000MHz2pF+/-20ppm+/-20ppm-40to+85℃
Q22FA23V00533003.2x2.5x0.7mmFA-238V5.000000MHz20pF+/-18ppm+/-22ppm-40to+85℃
     智能健身镜系列产品中用到的晶振一般为2520晶振及3225晶振这两款主流封装。有一款好的智能健身镜,其电路板上使用的晶振元件必须具备高精度、高稳定性的特点,这样才能保证智能健身镜的各项功能稳定有序地运作。智能健身镜使用的晶振类型,可根据其电路设计的需求选择无源品振或有源晶振方案。无源晶振需要外接电容与之匹配,而有源晶振输入额定电压即可输出所需时钟信号,具有更高稳定性及抗干扰等显著优势。
评论(0)
发评论
下载排行榜
