爱普生LV-PECL贴片晶振X1M0003110007,XG-2121CA低损耗6G晶振
消耗积分:0 | 格式:docx | 大小:400.46 KB | 2024-07-05
Piezoman压电侠
  • 914内容
  • 99w+阅读
  • 70粉丝
   X1M0003110007,XG-2121CA爱普生LV-PECL贴片晶振,低损耗6G晶振,日本进口晶振,EPSON爱普生晶振,型号为: XG-2121CA编码为:X1M0003110007,频率为:133.000000MHz,小体积晶振尺寸7.0x5.0mm,是-款LV-PECL差分 晶体振荡器,六脚贴片晶振,石英晶振,电源电压2.5V,3.3V,SPXO石英晶体振荡器,差分晶振作为目前行业中高要求,高 技术石英晶体振荡器,具有低相位噪声,低抖动,低功耗,低损耗,低电源电压,低电平等特点。使用于产品中能够很容易地 识别小信号,能够从容精确地处理'双极'信号,对外部电磁干扰(EMI)是高度免疫的。适用于通信网络,无线网络,蓝牙模 块,机顶盒、光端机、安防设备、路由器/交换机、仪器仪表、测试血糖仪,SAS,光纤通信,10G以太网及各种频率控制设备 上。
    差分晶振常见的尺寸是2520晶振,3225晶振,5032晶振,7050晶振三种封装尺寸。文中所列举的是爱普生7050体积的部分差分晶振编码。均为较高的频率点,为LV-PECL晶振输出方式,电源电压范围2.5V/3.3V,振荡启动时间在电源电压最低时,所需时间为0秒。爱普生的差分晶振具有性能强,精密稳定,低电压的特征,普遍用于对于高速网络要求的应用。
石英晶体振荡器品牌型号频率尺寸输出方式电源电压
X1M0003110002EPSON晶振XG-2121CA100.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110003EPSON晶振XG-2121CA133.330000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110004EPSON晶振XG-2121CA150.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110005EPSON晶振XG-2121CA156.250000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110006EPSON晶振XG-2121CA212.500000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110007EPSON晶振XG-2121CA133.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110008EPSON晶振XG-2121CA125.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110009EPSON晶振XG-2121CA312.500000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110010EPSON晶振XG-2121CA200.000000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110011EPSON晶振XG-2121CA156.250000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110012EPSON晶振XG-2121CA250.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110013EPSON晶振XG-2121CA500.000000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110014EPSON晶振XG-2121CA25.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110015EPSON晶振XG-2121CA106.250000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110016EPSON晶振XG-2121CA27.500000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110017EPSON晶振XG-2121CA136.718750 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110018EPSON晶振XG-2121CA98.304000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110020EPSON晶振XG-2121CA156.250000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110021EPSON晶振XG-2121CA625.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110022EPSON晶振XG-2121CA00.000000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110023EPSON晶振XG-2121CA322.265625 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110024EPSON晶振XG-2121CA161.132800 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110025EPSON晶振XG-2121CA200.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110026EPSON晶振XG-2121CA135.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110027EPSON晶振XG-2121CA100.000000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625 V
X1M0003110028EPSON晶振XG-2121CA125.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110029EPSON晶振XG-2121CA125.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110030EPSON晶振XG-2121CA156.250000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110031EPSON晶振XG-2121CA156.250000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110032EPSON晶振XG-2121CA250.000000 MHz7.00x5.00x1.20 mmLV-PECL2.375 to 2.625 V
X1M0003110033EPSON晶振XG-2121CA312.500000 MHz7.00x5.00x1.20 mmV-PECL2.375 to 2.625V
评论(0)
发评论
下载排行榜
