TDC-GPX_Datasheet
消耗积分:0 | 格式:pdf | 大小:653KB | 2016-07-15
吴建伟
分享资料个
The TDC-GPX time measurement is based on internal propagation delays. Those delays depend on temperature and voltage. They also vary over the production lots. The resolution adjust mode (see) uses the voltage dependency to compensate for temperature and production variations and sets the circuits to a fixed and programmable resolution.
评论(0)
发评论
下载排行榜
