AD8225,pdf datasheet (Instrumentation Amplifier)
消耗积分:5 | 格式:rar | 大小:372 | 2009-08-27
分享资料个
The AD8225 is an instrumentation amplifier with a fixed gain
of 5, which sets new standards of performance. The superior
CMRR of the AD8225 enables rejection of high frequency
common-mode voltage (80 dB Min @ 10 kHz). As a result,
higher ambient levels of noise from utility lines, industrial
equipment, and other radiating sources are rejected. Extended
CMV range enables the AD8225 to extract low level differential
signals in the presence of high common-mode dc voltage levels
even at low supply voltages.
Ambient electrical noise from utility lines is present at 60 Hz
and harmonic frequencies. Power systems operating at 400 Hz
create high noise environments in aircraft instrument clusters.
Good CMRR performance over frequency is necessary if power
system generated noise is to be rejected. The dc to 10 kHz
评论(0)
发评论
下载排行榜
