AD822,pdf datasheet (Low Power
消耗积分:3 | 格式:rar | 大小:589 | 2009-08-28
分享资料个
The AD822 is a dual precision, low power FET input op amp
that can operate from a single supply of 3 V to 36 V or dual supplies of ±1.5 V to ±18 V. It has true single-supply capability
with an input voltage range extending below the negative rail,
allowing the AD822 to accommodate input signals below
ground in the single-supply mode. Output voltage swing extends to within 10 mV of each rail, providing the maximum
output dynamic range.
评论(0)
发评论
下载排行榜
