The AD8631 brings precision and bandwidth to the SOT-23-5
package at single supply voltages as low as 1.8 V and low supply
current. The small package makes it possible to place the AD8631
next to sensors, reducing external noise pickup.
The AD8631 and AD8632 are rail-to-rail input and output bipolar
amplifiers with a gain bandwidth of 4 MHz and typical voltage
offset of 0.8 mV from a 1.8 V supply. The low supply current and
the low supply voltage makes these parts ideal for battery-powered
applications. The 3 V/μs slew rate makes the AD8631/AD8632 a
good match for driving ASIC inputs, such as voice codecs.
The AD8631/AD8632 is specified over the extended industrial
(–40C to +125C) temperature range. The AD8631 single is
available in 5-lead SOT-23 surface-mount packages. The dual
AD8632 is available in 8-lead SOIC and μSOIC packages.
