max2650 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-06-30
贾飞世
分享资料个
The MAX2650 is a low-noise amplifier for use from DC
to microwave frequencies. Operating from a single +5V
supply, it has a flat gain response to 900MHz. The
MAX2650’s low noise figure and high drive capability
make it ideal for a variety of transmit, receive, and
buffer applications.
The device is internally biased, eliminating the need for
external bias resistors or inductors. In a typical applica-
tion, the only external components needed are input
and output blocking capacitors and a VCC bypass
capacitor.
The MAX2650 comes in a 4-pin SOT143 package,
requiring minimal board space.
________________________Applications
Wireless Local Loop
Global Positioning Systems (GPS)
ISM Radios
Special Mobile Radios
Wireless Local-Area Networks
Cellular Base Stations
Set-Top Boxes
评论(0)
发评论
下载排行榜
