AD7708,pdf datasheet (Low Powe
消耗积分:3 | 格式:rar | 大小:680 | 2009-09-09
分享资料个
The AD7708/AD7718 are complete analog front-ends for low
frequency measurement applications. The AD7718 contains a
24-bit Σ-Δ ADC with PGA and can be configured as 4/5 fullydifferential
input channels or 8/10 pseudo-differential input
channels. Two pins on the device are configurable as analog
inputs or reference inputs. The AD7708 is a 16-bit version of
the AD7718. Input signal ranges from 20 mV to 2.56 V can be
directly converted using these ADCs. Signals can be converted
directly from a transducer without the need for signal conditioning.
评论(0)
发评论
下载排行榜
