AD1974,pdf datasheet (24-Bit C
消耗积分:3 | 格式:rar | 大小:254 | 2009-09-11
分享资料个
The AD1974 is a high performance, single-chip codec that pro-vides four analog-to-digital converters (ADCs) with differential inputs using the Analog Devices, Inc. patented multibit sigma-delta (Σ-Δ) architecture. An SPI port is included, allowing a microcontroller to adjust volume and many other parameters. The AD1974 operates from 3.3 V digital and analog supplies. The AD1974 is available in a single-ended output 48-lead LQFP.
评论(0)
发评论
下载排行榜
