HS-303ARH, HS-303BRH,pdf,datas
消耗积分:5 | 格式:rar | 大小:88 | 2009-09-11
分享资料个
The HS-303ARH and HS-303BRH analog switches are
monolithic devices fabricated using Intersil’s dielectrically
isolated Radiation Hardened Silicon Gate (RSG) process
technology to insure latch-up free operation. They are pinout
compatible and functionally equivalent to the HS-303RH, but
offer improved 300kRAD(Si) total dose capability. These
switches offers low-resistance switching performance for
analog voltages up to the supply rails. “ON” resistance is low
and stays reasonably constant over the full range of
operating voltage and current. “ON” resistance also stays
reasonably constant when exposed to radiation.
Break-before-make switching is controlled by 5V digital
inputs. The HS-303ARH should be operated with nominal
±15V supplies, while the HS-303BRH should be operated
with nominal ±12V supplies.
Specifications
Specifications for Rad Hard QML devices are controlled by
the Defense Supply Center in Columbus (DSCC). The SMD
numbers listed below must be used when ordering.
Detailed Electrical Specifications for the HS-303ARH and
HS-303BRH are contained in SMD 5962-95813. A “hot-link”
is provided from our website for downloading
评论(1)
发评论
谭纪生2012 2020-10-08
0 回复 举报
马克 收起回复
下载排行榜
全部1条评论
