ADN2811,pdf datasheet (IC with
消耗积分:2 | 格式:rar | 大小:541 | 2009-09-15
建立建利12
分享资料个
The choice of ac-coupling capacitors at the input (PIN, NIN) and output (DATAOUTP, DATAOUTN) of the ADN2811 must be chosen carefully. When choosing the capacitors, the time constant formed with the two 50 Ω resistors in the signal path must be considered. When a large number of consecutive identical digits (CIDs) are applied, the capacitor voltage can drop due to baseline wander (see Figure 22), causing pattern dependent jitter (PDJ).
评论(0)
发评论
下载排行榜
