AD9548,pdf datasheet (Generato
消耗积分:5 | 格式:rar | 大小:504 | 2009-09-15
12268
分享资料个
The AD9548 provides synchronization for many systems, including synchronous optical networks (SONET/SDH). The AD9548 generates an output clock synchronized to one of up to four differential or eight single-ended external input references. The digital PLL allows for reduction of input time jitter or phase noise associated with the external references. The AD9548 continuously generates a clean (low jitter), valid output clock even when all references have failed by means of a digitally controlled loop and holdover circuitry.
评论(0)
发评论
下载排行榜
