AD5259,pdf datasheet (256-Posi
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-22
李杰
分享资料个
The AD5259 provides a compact, nonvolatile LFCSP-10 (3 mm × 3 mm) or MSOP-10 (3 mm × 4.9 mm) packaged solution for 256-position adjustment applications. These devices perform the same electronic adjustment function as mechanical potentiometers1 or variable resistors, but with enhanced resolution and solid-state reliability.
评论(0)
发评论
下载排行榜
