ADN2526,pdf datasheet (Differe
消耗积分:3 | 格式:rar | 大小:510 | 2009-09-23
duke刘
分享资料个
The ADN2526 laser diode driver is designed for direct modula-tion of packaged laser diodes that have a differential resistance ranging from 5 Ω to 50 Ω. The active back-termination in the ADN2526 absorbs signal reflections from the TOSA end of the output transmission lines, enabling excellent optical eye quality to be achieved even when the TOSA end of the output transmission lines is significantly misterminated. ADN2526 is an SFP+ MSA-compliant device, and its small package and enhanced ESD protection provide the optimum solution for compact modules where laser diodes are packaged in low pin-count optical subassemblies.
评论(0)
发评论
下载排行榜
