ADG3232,pdf datasheet (2-1 Mux
消耗积分:3 | 格式:rar | 大小:556 | 2009-09-25
绝代双骄
分享资料个
The ADG3232 is a level translator 2-1 mux designed on a submicron process and operates from supplies as low as 1.65 V. The device is guaranteed for operation over the supply range 1.65 V to 3.6 V. It operates from two supply voltages, allowing bidirectional level translation, i.e., it translates low voltages to higher voltages and vice versa. The signal path is unidirectional, meaning data may flow only from A to Y.
评论(0)
发评论
下载排行榜
