ad7812/ad7811 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-07-13
胡秋阳
分享资料个
The AD7811 and AD7812 are high speed, low power, 10-bit
A/D converters that operate from a single +2.7 V to +5.5 V
supply. The devices contain a 2.3 ms successive approximation
A/D converter, an on-chip track/hold amplifier, a 2.5 V on-chip
reference and a high speed serial interface that is compatible
with the serial interfaces of most DSPs (Digital Signal Processors)
and microcontrollers. The user also has the option of using
an external reference by connecting it to the VREF pin and setting
the EXTREF bit in the control register. The VREF pin may
be tied to VDD. At slower throughput rates the power-down
mode may be used to automatically power down between
conversions.
评论(0)
发评论
下载排行榜
