WinHIIP_v1.7.6_汉化版
消耗积分:5 | 格式:rar | 大小:5.31 MB | 2017-03-28
叶云
分享资料个
PS2游戏机硬盘管理用的工具
  WinHIIP is a PC application used to install PS2 CD/DVD images onto a hard disk drive for use by HDLoader or one of its many derivatives including the greatly enhanced Toxic OS produced for the DMS4 Pro chip by Team Toxic.
  The primary reason for creating the application was to speed up the process of installing images onto the hard drive as installing these from the console could take up to 30 minutes where as on the PC this can be done in a couple of minutes.
  The hard disk drive currently has to be physically connected to your PC for the software to work. The speed is dependant on your connection method & windows configuration, it can be as slow as 1Mb/s using USB1, 12Mb/s using USB2 and up to 40Mb/s using IDE w
  winhiip是用来安装cd / dvd PS2的影像投射到一个硬盘驱动器用于hdloader或它的许多衍生物包括大大增强操作系统产生的有毒dms4 Pro芯片组毒PC机上的应用。
  创建应用程序的主要原因是加快安装图像到硬盘安装这些从控制台过程可能要花上30分钟在PC上的这几分钟可以做。
  硬盘驱动器目前已在物理上连接到您的PC的软件工作。速度是你的连接方法和Windows的配置,它可以为1MB依赖使用USB1 / S的速度缓慢,12Mb/s采用USB2,达到40Mb/s使用IDE。
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
