1. Driver installation (pick one of the two): a. If using SC-USB-SPI, then the SC-USB-SPI driver is automatically installed with the following steps. b. If using NI-USB-8451, then first install NI driver “NI845x_112_Installer” following the instructions in NI845x_112_driver_InstallGuide.pdf. Make sure the NI card is connected to the ribbon cable + connector provided with the EV kit following NI-USB- 8451_to_RFPAL2_Connector_pinout_mapping.xls. 2. Then, run the latest SetupScinteraGUIXXX.exe with the latest revision.
