Engineering Prototype Report f
消耗积分:2 | 格式:rar | 大小:551 | 2009-10-16
王毅山
分享资料个
Revolutionary control concept provides very low cost, low part count solution
• Primary side control eliminates secondary side control and opto-coupler
• Provides +/-5% CV and +/-10% CC accuracy including output cable drop for 24
AWG (0.3 Ohm) cable.
􀂃 Over-temperature protection – tight tolerance (+/-5%) with hysteretic recovery for
safe PCB temperature under all conditions
􀂃 Auto-restart output short circuit and open-loop protection
􀂃 Extended pin creepage distance for reliable operation in humid environments -
>3.2mm minimum at package
• EcoSmart® – Easily meets all current international energy efficiency standards – China
(CECP) / CEC / ENERGY STAR 1.1 / EU CoC
􀂃 No-load consumption <175mW at 265Vac
􀂃 Ultra-low leakage current: <5μA at 265Vac input (no Y capacitor required)
􀂃 Design to meets EN550022 and CISPR-22 Class B EMI with >10dBμV margin
• Meets IEC 61000-4-5 Class 3 AC line surge
The
评论(0)
发评论
下载排行榜
