PCF8591 pdf datasheet
消耗积分:10 | 格式:rar | 大小:666 | 2008-07-14
分享资料个
The PCF8591 is a single-chip, single-supply low power
8-bit CMOS data acquisition device with four analog
inputs, one analog output and a serial I
2C-bus interface.
Three address pins A0, A1 and A2 are used for
programming the hardware address, allowing the use of
up to eight devices connected to the I
2C-bus without
additional hardware. Address, control and data to and from
the device are transferred serially via the two-line
bidirectional I
2C-bus.
The functions of the device include analog input
multiplexing, on-chip track and hold function, 8-bit
analog-to-digital conversion and an 8-bit digital-to-analog
conversion. The maximum conversion rate is given by the
maximum speed of the I
2C-bus.
评论(1)
发评论
1066950103 2011-07-02
0 回复 举报
谢谢你的 ,资源很谢谢 收起回复
下载排行榜
全部1条评论
