LM86,datasheet,pdf(Temperature
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-20
cherry1989
分享资料个
The LM86 is an 11-bit digital temperature sensor with a
2-wire System Management Bus (SMBus) serial interface.
The LM86 accurately measures its own temperature as well
as the temperature of an external device, such as processor
thermal diode or diode connected transistor such as the
2N3904. The temperature of any ASIC can be accurately
determined using the LM86 as long as a dedicated diode
(semiconductor junction) is available on the target die. The
LM86 remote sensor accuracy of ±0.75°C is factory trimmed
for the 1.008 typical non-ideality factor of the mobile Pentium
™ III thermal diode. The LM86 has an Offset
register to allow measuring other diodes without
requiring continuous software management. Contact
to obtain the latest data for
new processors.
评论(0)
发评论
下载排行榜
