UCB1400 pdf datasheet
消耗积分:5 | 格式:rar | 大小:777 | 2008-07-16
杨海清
分享资料个
1. General description
The UCB1400 is a stereo audio codec equipped with touch screen and power
management interfaces. It integrates an AC ’97 Rev. 2.1 interface for communication
to an AC link host controller such as the Intel Xscale™ processor. The stereo audio
codec inputs connect directly to a microphone or line level sources such as a CD
player. The stereo audio codec outputs at line level and can drive a headphone
directly. The touch screen interface connects directly to a 4-wire resistive touch
screen. A built-in 10-bit analog-to-digital converter provides readout of touch screen
and power management parameters. Ten general-purpose I/O pins provide
programmable inputs and/or outputs to the system.
2. Features
n 48-pin LQFP surface mount package and low external component count for
minimal PCB space requirement
n Integrated AC ’97 Rev. 2.1 interface
n 20-bit stereo audio codec supporting programmable sample rates, and
input/output gain control
u Stereo line input and mono microphone input
u Stereo line/headphone output with bass/treble control
u Headphone driver with short circuit protection and virtual ground for DC
coupling
n 4-wire resistive touch screen interface circuit supporting position, pressure and
plate resistance measurements
n 10-bit successive approximation ADC with internal track-and-hold circuit and
analog multiplexer for touch screen readout and monitoring of four external high
voltage (7.5 V) sources
n Ten general purpose input/output pins
n 3.3 V supply voltage and built-in power saving modes for portable and battery
powered applications.
3. Applications
n Smart mobile phones
n Handheld PCs
n Palm-top PCs
n Personal Intelligent Communicators (PIC)
n Personal Digital Assistants (PDA).
评论(0)
发评论
下载排行榜
