外部汽车照明的LED额定热
虽然采用外部汽车应用LED的最明显的好处之一是设计的灵活性所带来的审美情趣,该技术带来了一些更根本的优势:增强的安全性,提高可靠性和降低整体成本。然而,有,并继续,一些设计挑战要克服。
汽车外部灯被认为是安全设备,因此高度管制。在汽车工程师协会(SAE)的专家已经确定,有三个主要因素,可以导致早期失败的LED灯:温度,振动和输入电压。因此,产品性能可靠性标准和测试程序围绕这些因素。
本文将考虑LED是如何发展,以满足汽车车灯制造商的性能和可靠性标准,并符合严格的汽车标准。
Figure 1: LEDs have allowed designers to unleash their creativity as well as improve performance and safety, as can be seen with the Audi A8
Reference will be made to extended temperature range operation and long life devices such as Osram’s Oslon Black Flat, Oslon LX and SX, Power SideLED and MultiLED ranges. In addition, Everlight’s Piranha range, destined for brake lights and signal indicators, is designed specifically to meet zero defect quality standards, focusing on heat dissipation as well as superior optical design.
