使用超级电容器的电压稳定
当电驱动机器启动时,它可能需要很高的电流从电源的一个短的时间内。这种电流的结果往往是一个不可接受的电压降,由于在电源网络中的阻抗。这种电压降可能导致连接到同一电网的其他设备的故障。因此,它是希望采取措施,以稳定电压在机器启动或其他类似的事件,这将导致短期电压瞬变。
能源储存技术,如电池已被提出来解决这些电压稳定问题。虽然电池可以储存和释放大量的能量在延长的时间段,他们有困难,提供短期的高功率水平所需的电压稳定。此外,电池充电缓慢,在某些应用中,它们的循环寿命短得多,通常不到一年或两年。此外,电池在寒冷的天气不好。这些因素限制了可接受的电池应用电压稳定。
Notice that the machine start is a short process, usually lasting less than a few seconds. During this process, a large amount of power is required. Ultracapacitors, which can economically supply high currents and deliver large amounts of power in time frames as long as a few minutes, can thus act as a supplemental power supply to stabilize the network voltage during the start of a machine. Therefore, the main power supply will be minimally affected. This means that other equipment connected to the main power supply will not be exposed to low voltage and be able to function normally.
