LED驱动器满足功率,空间和成本的挑战
LED照明设计人员通常寻找LED驱动器,提供低功耗,一个较小的系统包,当然,更低的成本(同时还提供高可靠性)在低到中等功率范围的应用。为了满足这种需求,LED驱动器制造商在他们的最新努力已纳入功率因数校正(PFC)电路,更高的电能质量,以及初级侧调节(PSR),以消除次级反馈电路,以降低成本。他们还使用反激式拓扑来简化设计。
LED驱动器制造商在他们的设计中使用PFC电路,以实现更好的电能质量-更低的功率损耗-以满足不同的区域监管标准。PSR做了一些其他有益的事情:它消除了输出电流感应损耗和所有二次反馈电路,从而使一个更高的效率LED驱动器的开发没有一个大的附带价格标签。它还允许更高的可靠性,因为它调节LED驱动器输出电压没有二次反馈电路。
One example is Fairchild Semiconductor’s FL7733A single-stage PSR flyback LED driver. This LED driver is designed to deliver constant brightness and instant flicker-free turn-on of LED lighting. The FL7733A with PSR lowers component count in low- to mid-power LED converters, eliminating the need for an input bulk capacitor and secondary feedback circuitry, which also drives down cost. Further contributing to space savings is the FL7733A controller’s small 8-pin small-outline package (SOP)。 The device is well suited for SSL downlights, as well as PAR and A19 bulb applications.
