新一代的POE控制器轻松地处理更高的功率
消耗积分:0 | 格式:rar | 大小:0.13 MB | 2017-06-19
分享资料个
 以太网第一功率(POE)标准,IEEE 802.3af,目的是为系统提供高达15.4的WDC在供电设备(考虑到在电缆运行帐户亏损后)。然而,增强PoE,PoE +(IEEE 802.3at)现在迎合系统提供多达25.5个WDC的连接设备。
  坡+越来越受欢迎,因为额外的电源处理能力允许工程师做比原来的标准更大的允许。硅供应商对PoE应用程序的组件进行了响应,这些组件可以满足POE的额外需求。例如,PoE +系统采用电源采购设备(PSE)控制器,对以太网电缆进行输入电源管理,并集成所需的电压调节器,以将输入电压转换为所需的系统。
  本文介绍了如何这些单片PSE控制器的介绍¬¬–设计处理高功率PoE +–需求使技术更容易实现,然后将描述一些最新产品的主要供应商。
  Flexible networking
  Perhaps the biggest benefit of PoE is its simplicity. The technology uses a single standard RJ45 connector (Figure 1) and CAT 5 (or even CAT 3) cable and can handle tens of watts – so once installed for communication, it can be used for power as well. That saves on materials, labor, installation time, and ongoing maintenance costs. Moreover, the centralized and flexible nature of the technology eliminates the need for each powered device (PD) on the network to have its own local power supply. That allows PDs to be placed anywhere and be easily relocated later if required.
评论(0)
发评论
下载排行榜
