了解交直流前端功率因数校正技术
根据定义,交流电源的功率因数(PF)被定义为实际功率的比率,即瓦特,流入电路中的表观功率,即电流和电压的乘积。它表示为PF =实功率(w)/视在功率(VA)。PF方程表明它是0到1之间的一个数字。因此,当电流和电压同相和正弦时,PF是1。然而,如果两者都是正弦的,但相位不一致,视在功率大于实际功率,PF是电流和电压波形之间相角的余弦。在实践中,PF = 1是理想情况下,负载是纯粹的电阻和线性。实际上,在电子系统中发现的离线交流/直流电源是开关模式,呈现非线性负载。
因为现在大多数电源都是开关模式,它们会产生非正弦波形,从而导致输入电流和电压之间的相位角。当电流波形不跟随电压波形时,它会导致低于1的PF。除了功率损耗外,1 pF的谐波会沿着中性线移动,并干扰连接到交流电源线的其他设备。PF数越低,交流线路的谐波含量越高,反之亦然。
Consequently, there are strict regulations to limit the harmonic distortion permitted on the AC mains line. For instance, Europe’s EN61000-3-2[1] was introduced to limit sending back reflected harmonics from electronic equipment into the mains. It is applicable to all class D electronic systems, such as PCs (including notebooks and PC monitors), and radio and TV receivers consuming more than 75 W. Class D is one of the four classes (A, B, C, and D) categorized by the EN61000-3-2 standard, which imposes different harmonic-current limits on each class. This standard is now accepted internationally.
