AFE芯片简化高精度电能计量设计
当公司寻找能源生产的替代能源时,测量和控制能源消耗的需求得到了更大的重视。对于工程师来说,可用的模拟前端(AFE)集成电路设计从创建精确的电能计量计费级电子米住宅智能能源监控系统提供的一个关键组成部分。加快发展这些设计,工程师可以利用精密计量AFE电路模拟设备,Cirrus Logic,Maxim集成产品和芯片技术,其中。
精确测量电流和电压,计算各种重要的能量参数,包括有功功率、无功功率和视在功率,以及并网应用所需的额外测量。虽然传统的机械式仪表需要达到至少2%的精度,但电子计量系统必须符合国家和国际标准,要求准确率为0.5%,在某些情况下必须达到0.2%。
For many applications, integrated energy-metering devices offer an excellent solution (see the TechZone article, “Energy Measurement ICs Provide Critical Metrics”)。 Where specialized requirements prevent use of these devices, however, engineers can build their own energy measurement solutions using dedicated devices to fill out the energy-metering signal chain, as seen in Figure 1. Here, sensor output drives precision analog-digital converters (ADC) in an analog measurement subsystem, which, in turn, presents data measurements or even final calculations to a DSP or MCU for additional analysis and eventual transmission through a communications subsystem.
