热管理的考虑满足lm-79和DOE卡尺测试程序
热管理参数不仅取决于LED的数据表,它们也是由政府授权。本文解释了这些参数以及如何满足这些参数。
无论是建立LED a19s,par38s,或任何其他类型的–灯以及LED灯具–你需要铭记的热管理问题。然而,如果你想在美国做生意,美国能源部和环境保护署(EPA)对于这个市场什么是可以接受的有一些话要说。设计灯联盟(DLC)也使用lm-79标准,所以记住这个设计时,LED照明产品的USA.
在第一阶段的评估,该产品的样品将在独立的实验室,如那些参与s-doe卡尺程序进行性能测试。为了实现一个DOE卡尺质量的LED解决方案,设计工程师需要一个有效的LED阵列,一个精心设计的电子驱动器,一个有效的散热片,和优化的光学解决方案的组合。这些关键项的正确组合直接决定了这些产品的有效性、光输出和寿命。的us-doe卡尺测试已经清楚地表明,一流的组件不能简单地拼凑出“品质”的产品。
本文讨论的重点应放在满足客户lm-79和DOE卡尺测试程序设计。
Design requirements
The list of requirements that DOE and EPA have laid out for LED lighting products can only be characterized as daunting. The luminaire designer must keep in mind a myriad of requirements:
CCT (IESNA LM-79, LM-58, LM-16, CIE 15-2004)
The four ANSI defined Macadam ellipses: 2700 k, 3000 k, 3500 k and 4000 k
Lumen depreciation (IESNA LM-80): 70 percent of initial lumen to 35,000 hours
Color spatial uniformity (IESNA LM-79, LM-58, LM-16, and CIE 15-2004)
Color maintenance (ANSI C78.377A, IESNA LM-79, LM-58, and CIE 13.3-1995)
80 CRI minimum (indoor)
Off-state power: zero
Warranty: three years
Thermal management: meet component supplier’s guidelines as well as key items for the LED driver/power supply/ballast
Power supply efficiency: 90 percent or more
FCC EMI/RFI: 47 CFR part 15/18 (consumer and non-consumer)
Transient protection (voltage spikes)
Frequency: 120 Hz or above
Noise: Class A, 24dB maximum
Power factor (ANSI C82.77): 0.90+ (commercial), 0.70+ (residential)
Temperature range: -20°C to maximum rating by power supply manufacturer
Safety (ANSI / UL 153, UL 1598)
