AT84AD001B pdf datasheet
消耗积分:5 | 格式:rar | 大小:777 | 2008-07-20
分享资料个
The AT84AD001B is a monolithic dual 8-bit analog-to-digital converter, offering low
1.4W power consumption and excellent digitizing accuracy. It integrates dual on-chip
track/holds that provide an enhanced dynamic performance with a sampling rate of up to
1 Gsps and an input frequency bandwidth of over 1.5 GHz. The dual concept, the integrated
demultiplexer and the easy interleaving mode make this device user-friendly for
all dual channel applications, such as direct RF conversion or data acquisition. The
smart function of the 3-wire serial interface eliminates the need for external components,
which are usually necessary for gain and offset tuning and setting of other
parameters, leading to space and power reduction as well as system flexibility.
评论(0)
发评论
下载排行榜
