高功率因数LED T8灯管更换
LED灯具替代白炽灯越来越多,但他们有一个伟大的未来取代荧光灯
本文介绍的原则和设计方程所需的高亮度LED灯的设计使用al9910高压LED控制器。方程是用来证明一个普遍的,离线设计,高功率因数(PF),13瓦LED灯适合使用作为一个T8荧光管的更换。提供了完整的设计,包括电气图、元件清单和性能测量。
高功率因数的al9910降压LED驱动器
Figure 1 shows the electrical diagram of an offline 13 W LED driver.
On the input side, CX1, CX2, CX3, CX4, L1, and L2 provide sufficient filtering for both differential mode and common mode EMI noise generated by the switching converter circuit.
The rectified AC line voltage from the bridge rectifier DB1 is then fed into a passive power factor correction or valley-fill circuit, which consists of three diodes and two capacitors. D1, D2, D3, C1, and C2 improve the input line current distortion in order to achieve a PF greater than 0.9 for the AC line input.
