车辆位置传感
磁霍尔效应编码器是强大的,并提供高精度和精确的位置信息,在恶劣的环境条件下所经历的车辆。
角和运动传感器广泛应用于车辆,如踏板位置传感和油门控制,以及用于变速器和方向盘。它几乎不需要说明,特别是在转向系统和节气门,可靠的操作对驾驶员、乘客、其他道路使用者和行人的安全是绝对必要的。汽车传感器,然后,必须是非常强大和可靠执行车辆的生活。
与此同时,汽车电磁兼容标准也越来越严格,新一代低碳柴油机和汽油机的开发要求更高的分辨率和低功耗的传感器性能。例如,在控制应用中,汽车设计师正在寻找吸引超低待机电流元件。甚至有一个走向‘需求的减少控制电路功耗测量。
Sensors also need to adapt to new digital interfaces such as single-edge nibble transmission (SENT) protocol and Peripheral Sensor Interface 5 (PSI5), which will replace traditional analog outputs.
All of these factors in combination are accelerating the elimination of traditional contacting-sensor solutions and their replacement by contactless sensors.
ams has pioneered the development of integrated Hall effect encoder solutions, optimizing its AS5xxx series sensors for automotive applications. This article describes how robust performance in challenging automotive conditions is facilitated by the use of a patented differential sensor technology.
