ISL28191, ISL28291单和双单电源超低噪声低失真的轨到轨输出Op Amp
消耗积分:0 | 格式:rar | 大小:1.58 MB | 2017-09-15
分享资料个
  The ISL28191 and ISL28291 are tiny single and dual ultra-low noise, ultra-low distortion operational amplifiers. They are fully specified to operate down to +3V single supply. These amplifiers have outputs that swing rail-to-rail and an input common mode voltage that extends to ground (ground sensing)。 The ISL28191 and ISL28291 are unity gain stable with an input referred voltage noise of 1.7nV/Hz. Both parts feature 0.00018% THD+N at 1kHz. The ISL28191 is available in the space-saving 6 Ld UTDFN (1.6mmx1.6mm) and 6 Ld SOT-23 packages. The ISL28291 is available in the 8 Ld SOIC, 10 Ld 1.8mmx1.4mm UTQFN and 10 Ld MSOP packages. All devices are guaranteed over -40°C to +125°C.
评论(0)
发评论
下载排行榜
