FeaturesMechanical DataThe plastic material used carries UnderwritersLaboratory flammability recognition 94V-0
Single In-Line terminals array suitable for P.C. boardmounting
Surge overload ratings to 250 amperes peakHigh temperature soldering guaranteed 265 C/10seconds/.375“(9.5mm) lead length at 5 lbs (2.3kg)tensionCase: Molded plasticTerminals: Plated wire leads solderable per MIL-STD-202,Method 208Mounting Position: AnyWeight: 0.3 ounce, 8 grams (approx)Mounting Torque: 5 in-lb maxi
