Hallwee HAL246R全极低功耗霍尔开关高频率磁控管
消耗积分:0 | 格式:pdf | 大小:2312KB | 2017-09-20
hallwee
分享资料个
Hallwee HAL246R全极低功耗霍尔开关 高频率磁控管 OPEN DRAIN推挽式输出,Hallwee成立于2011年,专做霍尔开关,品牌HALLWEE,为解决客户对其品质的担忧,公司寻找国内外极其成熟的霍尔元件芯片晶圆,并辅以国内测试封装,成为以低成本/高品质/高性价比的霍尔元件(霍尔开关)优质供应商,短短几年就在国内市场占领一席之地,并且销量每年都在稳定增涨。HAL246R霍尔开关
  HAL246R Hall-effect sensor is a temperature stable, stress-resistant, Low Tolerance of Sensitivity micro-power switch. Superior high-temperature performance is made possible through a dynamic offset cancellation that utilizes chopper-stabilization. This method reduces the offset voltage normally caused by device over molding, temperature dependencies, and thermal stress. is special made for low operation voltage, 1.7V, to active the chip which is includes the following on a single silicon chip: voltage regulator, Hall voltage generator, small-signal amplifier, chopper stabilization, Schmitt trigger, CMOS output driver. Advanced CMOS wafer fabrication processing is used to take advantage of low-voltage requirements, component matching, very low input-offset errors, and small component geometries. This device requires the presence of omni-polar magnetic fields for operation. The package type is in a Halogen Free version has been verified by third party Lab.
评论(0)
发评论
下载排行榜
