ah337单相霍尔效应开关
消耗积分:0 | 格式:rar | 大小:0.16 MB | 2017-09-22
分享资料个
  AH337 is an unipolar Hall-Effect sensor for contactless switching applications. The device includes an on-chip Hall voltage generator for magnetic sensing, an amplifier that amplifies the Hall voltage, a Schmitt trigger to provide switching hysteresis for noise rejection, and an open-collector output. The band-gap regulator allows a wide operating voltage range. When the magnetic flux density (B) is larger than operate point (Bop), output is switched on (OUT pin is pulled low)。 The output state is held on until a magnetic flux density falls below Brp. When B is less than Brp, the output is switched off. The AH337 is available in SIP-3L and SC59 packages.
ah337单相霍尔效应开关
评论(0)
发评论
下载排行榜
