Freescale Semiconductor MC9RS0
消耗积分:3 | 格式:rar | 大小:223 | 2009-12-03
分享资料个
This device contains circuitry protecting against damage due to high static voltage or electrical fields; however, it is advisedthat normal precautions be taken to avoid application of any voltages higher than maximum-rated voltages to thishigh-impedance circuit. Reliability of operation is enhanced if unused inputs are tied to an appropriate logic voltage level (for
instance, VSS or VDD) or the programmable pull-up resistor associated with the pin is enabled.
评论(0)
发评论
下载排行榜
