Voltage regulator
The voltage divided by resistors R1 & R2 is compared with the internal reference voltage by the error amplifier
The MOSFET, which is connected to the Vout pin, is then driven by the subsequent output signal. The output voltage at the Vout pin is controlled & stabilized by a system of negative feedback.
