74HC107 pdf datasheet
消耗积分:3 | 格式:rar | 大小:133 | 2008-08-06
吴湛
分享资料个
MM54HC107/MM74HC107
Dual J-K Flip-Flops with Clear
General Description
These J-K Flip-Flops utilize advanced silicon-gate CMOS
technology to achieve the high noise immunity and low power
dissipation of standard CMOS integrated circuits. These
devices can drive 10 LS-TTL loads.
These flip-flops are edge sensitive to the clock input and
change state on the negative going transition of the clock
pulse. Each one has independent J, K, CLOCK, and CLEAR
inputs and Q and Q outputs. CLEAR is independent of the
clock and accomplished by a low level on the input.
The 54HC/74HC logic family is functionally as well as pinout
compatible with the standard 54LS/74LS logic family.
All inputs are protected from damage due to static discharge
by internal diode clamps to VCC and ground.
评论(0)
发评论
下载排行榜
