MM54HC157/MM74HC157 Quad 2-Input Multiplexer MM54HC158/MM74HC158 Quad 2-Input Multiplexer (Inverted Output) General Description These high speed Quad 2-to-1 Line data selector/Multiplexers utilize advanced silicon-gate CMOS technology. They possess the high noise immunity and low power consumption of standard CMOS integrated circuits, as well as the ability to drive 10 LS-TTL loads. These devices each consist of four 2-input digital multiplexers with common select and STROBE inputs. On the MM54HC157/MM74HC157, when the STROBE input is at logical ``0'' the four outputs assume the values as selected from the inputs. When the STROBE input is at a logical ``1'' the outputs assume logical ``0''. The MM54HC158/ MM74HC158 operates in the same manner, except that its outputs are inverted. Select decoding is done internally resulting in a single select input only. If enabled, the select input determines whether the A or B inputs get routed to their corresponding Y outputs. The 54HC/74HC logic family is functionally as well as pinout compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground. Features Y Typical propagation delay: 14 ns data to any output Y Wide power supply range: 2±6V Y Low power supply quiescent current: 80 mA maximum (74HC Series) Y Fan-out of 10 LS-TTL loads Y Low input current: 1 mA maximum
