74HC4040 pdf datasheet
消耗积分:10 | 格式:rar | 大小:133 | 2008-08-06
分享资料个
MM54HC4020/MM74HC4020
14-Stage Binary Counter
MM54HC4040/MM74HC4040
12-Stage Binary Counter
General Description
The MM54HC4020/MM74HC4020, MM54HC4040/
MM74HC4040, are high speed binary ripple carry counters.
These counters are implemented utilizing advanced silicongate
CMOS technology to achieve speed performance similar
to LS-TTL logic while retaining the low power and high
noise immunity of CMOS.
The 'HC4020 is a 14 stage counter and the 'HC4040 is a 12-
stage counter. Both devices are incremented on the falling
edge (negative transition) of the input clock, and all their
outputs are reset to a low level by applying a logical high on
their reset input.
These devices are pin equivalent to the CD4020 and
CD4040 respectively. All inputs are protected from damage
due to static discharge by protection diodes to VCC and
ground.
Features
Y Typical propagation delay: 16 ns
Y Wide operating voltage range: 2±6V
Y Low input current: 1 mA maximum
Y Low quiescent current: 80 mA maximum (74HC Series)
Y Output drive capability: 10 LS-TTL loads
评论(0)
发评论
下载排行榜
