The TC1030 is a quad CMOS operational amplifier designed for low power applications. It has a typical operating supply current of 20μA which is constant over the supply voltage range of 1.8V to 5.5V. Each op amp has rail-to-rail inputs and output which allow operation at low supply voltages with large input and output signal swings. Two active low shutdown pins are provided. One pin disables op amp B while the other disables op amps C and D. Op amp A is always active.When disabled, the outputs of op amps B, C and D are in a high impedance state. Packaged in a 16-Pin QSOP, the TC1030 is ideal for battery operated applications. The TC1030 is packaged in a 16-Pin QSOP, making it ideal for battery operated applications.
