AAT3113, AAT3114/AAT3114A,pdf
消耗积分:5 | 格式:rar | 大小:221 | 2010-01-30
分享资料个
The AAT3113 and AAT3114/14A are low noise, constant frequency charge pump DC/DC converters that use fractional (1.5X) conversion to increase efficiency in white
LED applications. The devices can be used to produce current levels up to 20mA for each output from a 2.7V to 5.5V input. A low external parts count (two 1μF flying
capacitors and two small bypass capacitors at VIN and OUT) makes these devices ideally suited for small, battery- powered applications.
评论(0)
发评论
下载排行榜
