AAT3119,pdf datasheet(High Eff
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-30
分享资料个
The AAT3119 is a general purpose high efficiency voltage regulated charge pump IC that can produce output current levels up to 150mA. As a voltage regulated output device, it may be used for general voltage boost applications or to power white, RGB, or flash type LEDs from a
2.7V to 5.5V input.
评论(0)
发评论
下载排行榜
