超微 X6DA3-G2主板英文版/说明书
消耗积分:0 | 格式:rar | 大小:2315 | 2010-02-09
huyanai202
分享资料个
超微 X6DA3-G2主板英文版说明书.zip
主板的安装步骤:
1.确认主板配件
2.安装CPU
3.安装内存
4.查证跳线是否正确
5.然后安装在机箱
6.安装扩展支架或所有接线
7.安装其它的设备,并确认正确连接到主板接口。
注意:
A.在安装主板时,先把JCS设为正常模式,设置方法请看本章节对JCS的说
明进行设置。
B.安装主板前,请不要将ATX电源通电,连接到主板上,否则会损坏主板。
Safety Instructions
1. Always read the safety instructions carefully.
2. Keep this User Manual for future reference.
3. Keep this equipment away from humidity.
4. Lay this equipment on a reliable flat surface before setting it up.
5. The openings on the enclosure are for air convection hence protects the equipment from overheating. Do not cover the openings.
6. Make sure the voltage of the power source and adjust properly 110/220V before connecting the equipment to the power inlet.
7. Place the power cord such a way that people can not step on it. Do not place anything over the power cord.
8. Always Unplug the Power Cord before inserting any add-on card or module.
9. All cautions and warnings on the equipment should be noted.
评论(0)
发评论
下载排行榜
