多被动传感器系统航迹融合原理开发
消耗积分:5 | 格式:rar | 大小:298 | 2010-02-26
张涛
分享资料个
多被动传感器系统航迹融合原理开发
多被动传感器系统以其隐蔽特性得到重视,然而缺乏针对其独有,特性的航迹融合法。本文分析了其信息接收特性和信息分布特性,在此基础上提出了“参数+位置”航迹关联算法和以CEP为权因子的航迹融合算法,并以典型系统交叉和时差定位系统为例进行仿真,验证了此方法的有效性,为解决多被动传感航迹融合问题提供了新的途径。
Multi-passive-sensor system draw much attention because of its hidden character,but the track fusion algorithma gainstits u niquep ropertyi sla ck.Thep orpertyo fin formaitonr eceivinga ndd istribuitonis st udied,andth e"signal parameter+location"track correlation algorithm and the weighted track fusion method with weight CEP are put forward.Two typical system cross bearing system and time-of-arrival location system are emulated.Finally the
effectivity of this method is proved.
评论(0)
发评论
下载排行榜
